LuisB
Sep 03, 2015Aspirant
Issue with connectivity to a NAS connected to GS108T
I have installed a CTERA C200 NAS on my network with has a TWC Router (ADDIS) and it then feeds to my Netgear GS108T. The NAS requires the opening of ports 995 and 873 and I have setup the router to...
- Sep 06, 2015
Hi,
I think I found the problem. The NAS had a different IP address. So I had to modify the port virtual server addresses to match the IP and that did the job.
Thx
Luis
LuisB
Sep 06, 2015Aspirant
I will check with the router/modem settings. I however see that the GT108 has port trigger settings. What are those for?
Luis
LuisB
Hi,
Thx
Luis
- JohnRoSep 07, 2015NETGEAR Employee Retired
Hello LuisB,
Glad you found the issue, the port trigger setting (if there is one included on the FW) is only for internal packets so this does not involve request coming from the WAN.
If you have more questions, please feel free to post.
Thanks,
