coconutneu
Aug 26, 2025Aspirant
Issue with PoE Interface on GS728TPPv2
Hello everyone, I'm experiencing a persistent issue with the PoE interface on my NETGEAR GS728TPPv2 switch. The interface seems to be constantly loading and doesn't respond even after updating t...
Aug 26, 2025Guru - Experienced User
Does this happen with all devices disconnected from the switch and just one wired PC?
Happens with a different browser?
With everything disconnected, try a factory reset on the switch then setup from scratch?
- coconutneuAug 26, 2025Aspirant
Thanks for the quick response, the switch is located on a frame eight metres high, which makes it difficult for me to access. I've tried using different browsers, but nothing has changed.
Initially, there was a PoE-powered camera that kept disconnecting. Upon investigation, I found that the link speed was only 100 Mbps. When I opened the settings, I saw a 'PoE Max' warning. That's why I want to look into the PoE settings, maybe they're connected.
