coconutneu
Aug 26, 2025Aspirant
Issue with PoE Interface on GS728TPPv2
Hello everyone, I'm experiencing a persistent issue with the PoE interface on my NETGEAR GS728TPPv2 switch. The interface seems to be constantly loading and doesn't respond even after updating t...
schumaku
Aug 26, 2025Guru - Experienced User
The standard reason for such effects like the "Loading Page" is a hardware issue, where the PoE controller is no longer workable (read defect!), probably doesn't allow to provide PoE power to the ports.
Worth a try is flashing the current firmware again lnc finished, followed by the required cold reboot, and see...
Head to https://my.netgear.com/ and file a harder issue report. Nothing the community can do for you here I'm afraid.
-Kurt.
- coconutneuAug 26, 2025Aspirant
Hi Kurt, thanks for your insight. I also suspect that it might be a hardware failure. However, all the PoE-powered cameras seem to be working normally except for the one on port 13. Is there anything else I can do to debug the issue besides physically disconnecting the camera? In the meantime I will also seek advice from technical support.
- FURRYe38Aug 26, 2025Guru - Experienced User
Wow that high? Seems a bit limiting having that switch out of reach for troubleshooting when that is needed.
You may need to get up there and disconnect the one camera and see if you continue to see the log entries. Seems like of other cameras and such are working good and this one camera is exhibiting issues, could be camera related which needs to be reviewed closer phycically with all connections.
