mikedeck
Jul 24, 2023Follower
JGS516PE using VLAN for Management Interface
I have a JGS516PE Smart Managed Plus switch that I have configured with three VLANs. I've configured the port that connects to my router to 'T' for the three VLANs and 'U' for the default VLAN (01). ...
brianegge
Dec 31, 2023Aspirant
I'm running into the same issue. I have the router getting it's IP via DHCP and it switched to a different LAN. I thought maybe it was just trying to get DHCP from the highest port (16), so I made my uplink port 16. Same issue.
It's not critical - just odd. The VLANs for the devices all work OK. I'd prefer the VLANs to not have access to the management interface, but that seems unavoidable here. I'm running firmware 2.6.0.48, which is the latest available.
- schumakuJan 01, 2024Guru - Experienced User
Correct. And nothing we can do or change. Thank you for reading and understanding of what some community members explain here.
- brianeggeJan 01, 2024Aspirant
I'd like to figure out if it will work if I set the switch to use a static IP on the management vlan. But I'm worried if I try it and it doesn't work, I'll have a difficult time changing it back.
Nothing you can loose doing the experiment - nothing will change with the static IP assignment however: Still the same uC listening on the very same L2 network, the IP stack is operating untagged in the same broadcast domain.
