DigitalSurfer's avatar
May 31, 2025
JGS524Ev2 won’t factory reset with paper clip. Can’t apply any changes in management
Hello,
 I would be grateful for some help. I was thinking I would update the firmware to the latest version but when I log on to the switch the apply button won’t highlight or do anything. I tried to reset the switch to factory settings using a paper clip as per instructions. But it won’t reset and I cannot make any changes. Any help appreciated. Thank you.
  • Hello again schumaku,
    I was just about to reply, but thought I would just log back in to the WebUI to check again if I could make it work.
    A strange thing happened! I noticed that the cancel and apply buttons were partly off the bottom of the screen... So I decided to reduce the zoom level of the monitor to see if they became fully visible...
    Amazingly, the entire WebUI layout changed and all of the management functions became available!
    I am pleased to report that I have been successful in updating the firmware and we are now on the newest version.
    Thank you for your help indeed.
    I wish you all the best and take care.
  • schumaku's avatar
    schumaku
    Certain browser disallow submitting passwords (and probably more) on simple http connections and http forms as required by these very basic WebUI on the Plus switches.
    • DigitalSurfer's avatar
      DigitalSurfer
      Hi there schumaku, thank you for the reply.
      I can access the management WebUI with my password ok. But when I am in the WebUI, and having selected something like... say Firmware upgrade for example, the  apply button won’t highlight or do anything. I tried to reset the switch to factory settings using a paper clip as per instructions. But it won’t reset and I cannot make any changes?
      I have searched to see if there is a solution but cannot find an answer for this problem anywhere! Is there something I'm missing?
      Thank you.
      • schumaku's avatar
        schumaku
        Is this after selecting the firmware file (of course permitting you had unzipped the archive before, storing on the local PC or Mac?
ProSupport for Business
