patch2
May 26, 2022Aspirant
JGS524PE Lock up under prolonged load
Under prolonged load the switch stops routing. My questions are: Is there a recognised fix for this? If there is no fix, is this a recognised problem which other Netgear switches do not have? If...
Marc_V
May 27, 2022NETGEAR Employee Retired
Welcome to the Community!
We have not seen any reported issues about this. I would definitely suggest getting in touch with Support by creating a case via online or phone so they can gather more information and try to troubleshoot or replicate before submitting this issue.
HTH
