kdwilliams's avatar
Aug 26, 2015
JGS524PE Regularly Hangs, Stopping all Traffic, and Requires a Reboot
i have a JGS524PE PoE switch which is currently under test, prior to being installed in the network. At least once every 24 hour period the switch hangs and needs to be rebooted. During the hang, all...
  • JohnRo's avatar
    JohnRo
    Oct 01, 2015
    Hi kdwilliams,
    For now, using the older firmware is our workaround and only used it to isolate the issue. However, if you will continue to get the issue I suggest you contact support. I have checked your products that are registered on our system and the JGS524PE is under our lifetime warranty, so if determined that this is a hardware issue you can still have it replaced. This device does not have a lot of features since it is only an Unmanaged Plus Switch.
    I hope my answer helps. If you have more questions, we'll be happy to assist.
    Thanks,
ProSupport for Business
