hummous's avatar
hummous
Guide
Sep 25, 2022
LAG between Unifi Aggregation switch and Netgear switch keeps failing
I set up a LAG on ports 1 and 2 on Unifi Aggregation switch. Ports 1 and 2 are connected to the 2 SFP+ ports on the Netgear switch with 2 DAC cables. Options on the Netgear are set to LACP, Link Trap...
  • hummous's avatar
    hummous
    Sep 26, 2022
    Nevermind I solved it myself. Enabling Spanning Tree Protocol (STP) on the switch and the LAG group fixed it. The Netgear switch is now connected to my Unifi switch at 20Gbps.
ProSupport for Business
