hummous
Sep 25, 2022Guide
LAG between Unifi Aggregation switch and Netgear switch keeps failing
I set up a LAG on ports 1 and 2 on Unifi Aggregation switch. Ports 1 and 2 are connected to the 2 SFP+ ports on the Netgear switch with 2 DAC cables. Options on the Netgear are set to LACP, Link Trap...
- Sep 26, 2022
Nevermind I solved it myself. Enabling Spanning Tree Protocol (STP) on the switch and the LAG group fixed it. The Netgear switch is now connected to my Unifi switch at 20Gbps.
DaneA
Sep 25, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
What is the model of the SFP+ module that you are using between the MS510TXUP and the Unifi Aggregation switch?
What is the current firmware version of the MS510TXUP?
Does the Unifi Aggregation switch supports LACP?
DaneA
NETGEAR Community Team
hummous
Sep 25, 2022Guide
The cable I'm using is https://www.amazon.com/dp/B09BF98L77?psc=1&ref=ppx_yo2ov_dt_b_product_details
MS510TXUP Boot version 1.0.0.7
MS510TXUP Software version 1.0.4.6
The Unifi switch supports LACP.
