rlatimer4
May 19, 2017Aspirant
Link Aggregation GS116Ev2 and GS108Tv2
I have a R8500 router connected to a GS108Tv2 with LACP link aggregation. That works fine. I also am attempting to connect my GS108Tv2 to a GS116Ev2 with static link aggregation, this works fo...
- May 21, 2017
The problem appears to have been caused by a bad ethernet cable on one of the ports.
XavierLL
May 19, 2017NETGEAR Employee Retired
HI rlatimer4,
The configuration that you described below seems correct however seems that instead a LAG a loop it's detected in your network.
Do you mind to share with us the config screenshoots of the GS108T and GS116Ev3 on the link Aggregation.
Moreover please check that you enable the LAG interface too.
Regards
Xavier Lleixa
NETGEAR CBU PLM
rlatimer4
Hi Xavier,
I do have admin mode enabled on both ends. Currently only one cable is plugged in. Here are the screen shots for the GS116Ev2, and below that the GS108Tv2. I did enable loop detection on the GS116Ev2, could that be causing the problem?
GS108T:
