Arnaud_D
May 25, 2018Aspirant
Link trap GS728TP
Hi,
I have a GS728TP and I wanted to know if there is any way to specify the Link Trap Settings on each port (Enable/Disable), as I can do on ALL my other switches, even GS108Tv2. 'Cause I don't wa...
- Oct 03, 2018
Hi Arnaud_D,
I apologize for the inconvenience for the late follow-up on this thread :(
As per the higher tier of NETGEAR Support, there is really no option to enable/disable Link Trap on the GS728TP switch.
You may want to post this as feature request in the Idea exchange for Business board here.
DaneA
NETGEAR Community Team
DaneA
May 28, 2018NETGEAR Employee Retired
Hi Arnaud_D,
Kindly answer the questions below:
a. On the web-GUI of the GS728TP switch, go to Switching > Ports > Port Configuration, is there an option for Link Trap just like in the GS108Tv2 switch? Kindly post a screenshot of it.
b. What is the current firmware version of the GS728TP switch? If ever its not the latest version, I suggest you to upgrade the firmware to the latest version which is v6.0.1.24. You can download it here. Be sure to perform a factory reset on the GS728TP switch right after upgrading the firmware then reconfigure the setting from scratch in order to start clean using the latest firmware version. Then, check if still the same problem.
DaneA
Arnaud_D
May 28, 2018Aspirant
Hi DaneA,
Here is the screenshot : No option for link trap, but I can see the alert in the log
- The switch has the last fw, it's the first thing I did.
Best regards,
- Arnaud_DJun 01, 2018Aspirant
Hello,
Any news ?
- DaneAJun 03, 2018NETGEAR Employee Retired
I already inquired your concern to the higher tier of NETGEAR Support and still waiting for feedback. I will post here once I got a response.
DaneANETGEAR Community Team
- DaneAOct 03, 2018NETGEAR Employee Retired
Hi Arnaud_D,
DaneA
