Arnaud_D
May 25, 2018Aspirant
Link trap GS728TP
Hi,
I have a GS728TP and I wanted to know if there is any way to specify the Link Trap Settings on each port (Enable/Disable), as I can do on ALL my other switches, even GS108Tv2. 'Cause I don't wa...
- Oct 03, 2018
Hi Arnaud_D,
I apologize for the inconvenience for the late follow-up on this thread :(
As per the higher tier of NETGEAR Support, there is really no option to enable/disable Link Trap on the GS728TP switch.
You may want to post this as feature request in the Idea exchange for Business board here.
DaneA
NETGEAR Community Team
DaneA
Jun 03, 2018NETGEAR Employee Retired
I already inquired your concern to the higher tier of NETGEAR Support and still waiting for feedback. I will post here once I got a response.
DaneA
DaneA
Oct 03, 2018NETGEAR Employee Retired
Hi Arnaud_D,
DaneA
