Arch_Jake
Oct 02, 2016Aspirant
Loss of management services following firmware upgrade
I've just attempted a firmware upgrade (to 1.3.0.1) on my GS105Ev2 Switch. Management through the Prosafe Plus Configuration Utility was working fine before upgrading. Following successful up...
- Oct 05, 2016
Hi Arch_Jake,
I advise you to open an online case with NETGEAR Support at anytime. State what happened to the GS105Ev2 switch and the troubleshooting steps we did. Attach a .pdf or .doc copy of the Proof of Purchase or Sales Invoice of your GS105Ev2 switch for warranty verification. If ever the hardware warranty is still valid, an online replacement will follow.
DaneA
NETGEAR Community Team
DaneA
Oct 03, 2016NETGEAR Employee Retired
Hi Arch_Jake,
Welcome to the community! :)
Try the steps below:
a. Disconnect the GS105Ev2 switch from your existing network.
b. Connect a PC (where the ProSAFE Plus Configuration Utility is installed) directly to the GS105Ev2 switch.
c. Assign a static IP address of 192.168.0.210 to the PC. The default IP address of the GS105Ev2 switch is 192.168.0.239.
d. Open command prompt then check if you can get replies when you ping the default IP address of the GS105Ev2 switch.
e. If you are able to get replies, open the ProSAFE Plus Configuration Utility and it should detect the GS105Ev2 switch.
f. If ever the switch is detected, set a static IP address on the GS105Ev2 switch that is within the IP range of your existing network.
g. Connect the GS105Ev2 switch back to your existing network.
h. Set the PC to obtain an IP address automatically.
i. Open command prompt again then check if you can get replies when you ping the static IP address you have set on the GS105Ev2 switch.
j. If you are able to get replies, open the ProSAFE Plus Configuration Utility and it should detect the GS105Ev2 switch again.
Let us know the results.
DaneA
