Arch_Jake
Oct 02, 2016Aspirant
Loss of management services following firmware upgrade
I've just attempted a firmware upgrade (to 1.3.0.1) on my GS105Ev2 Switch. Management through the Prosafe Plus Configuration Utility was working fine before upgrading. Following successful up...
- Oct 05, 2016
Hi Arch_Jake,
I advise you to open an online case with NETGEAR Support at anytime. State what happened to the GS105Ev2 switch and the troubleshooting steps we did. Attach a .pdf or .doc copy of the Proof of Purchase or Sales Invoice of your GS105Ev2 switch for warranty verification. If ever the hardware warranty is still valid, an online replacement will follow.
DaneA
NETGEAR Community Team
Arch_Jake
Oct 03, 2016Aspirant
Thanks for your time Dane,
Following the steps you've set out, I still can't get a response from the switch.
No response with a ping to the default IP address from the static IP you specified, and no response from the Prosafe Plus Utility.
DaneA
Oct 04, 2016NETGEAR Employee Retired
Hi Arch_Jake,
Kindly answer the questions below:
a. What is the behavior of the LED lights on the GS105Ev2 switch?
b. What is the version of the ProSAFE Plus Configuration Utility you are using? I recommend you to use the latest version which is v2.3.20. You may download it here.
DaneA
- Arch_JakeOct 04, 2016Aspirant
Ok: so when plugged into the network the power light is on, the active ports flash on the left-hand LED. Data is travelling through the switch no problem.
When plugged into the PC on a static IP, the power light is on and both LED's above the active port are on - but do not flash very often.
V.2.3.20 is installed - I've tried changing between the version on the installation CD and 2.3.20, with no luck.
- DaneAOct 04, 2016NETGEAR Employee Retired
Hi Arch_Jake,
Kindly try the steps below:
1. Disconnect the GS105Ev2 from your existing network and make sure its turned on. Get a straightened paper clip.
2. Insert the paper clip to the factory defaults hole then press and hold the factory reset button inside it for 30 seconds.
3. After 30 seconds, turn off the GS105Ev2 while you still continue to press and hold the factory reset button. Wait for 5 seconds.
4. After 5 seconds, turn on the GS105Ev2 switch while you still continue to press and hold the factory reset button. Wait for another 5 seconds.
5. After 5 seconds, release the paper clip from the factory reset button. Wait for the GS105Ev2 to boot up properly.
After doing the steps above, perform the steps I have sent you previously to check if the GS105Ev2 will be detected by the ProSAFE Plus Configuration Utility.
DaneA
Hi Dane,
No luck after the factory reset either.
- Jun 10, 2022Retired_Member
