GreenHell
Nov 01, 2016Aspirant
Management Interface unreachable when a connected webcam is viewed
Hello, I use the GS108PEv3 to connect an AXIS webcam to it. The switch provides PoE für the webcam. The webcam operates fine with the switch. When I use the live view (Full HD, 25fps, H264 codec) t...
- Nov 06, 2016
Hi GreenHell,
Kindly try to factory reset the GS108PEv3 back to factory defaults then reconfigure it from scratch and check if same problem will occur. Let us know the results.
DaneA
NETGEAR Community Team
GreenHell
Nov 04, 2016Aspirant
Hello DaneA, unfortunately I have neither another switch with PoE nor a power injector. Regards, Carsten
DaneA
Nov 06, 2016NETGEAR Employee Retired
Hi GreenHell,
DaneA
- GreenHellNov 06, 2016Aspirant
Hello DaneA,
the factory reset has been done. I observed that the IP address was still the same, but it was "manualy" configured instead of DHCP. Password was also reset to default.
I configured via web interface DHCP and name and the problem is gone. I rebooted the switch and the problem is gone - I hope forever.
In case you're interested I could provide you with the configuration file I saved just before the factory reset.
Thank you for your support.
Carsten
- DaneANov 06, 2016NETGEAR Employee Retired
Hi GreenHell,
You're welcome! :) I'm glad that the factory reset has helped.
For now, kindly observe for a few days if the problem will recur.
DaneA
- DaneANov 09, 2016NETGEAR Employee Retired
Hi GreenHell,
I just want to check if the everything is fine with the GS108PEv3 switch. Has the problem recurred?
DaneA
- GreenHellNov 10, 2016AspirantHello DaneA, the problem didn't recurr. Everything is fine. Regards, Carsten
- DaneANov 10, 2016NETGEAR Employee Retired
Hi GreenHell,
I'm happy to know that the problem did not recur. :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
