be_philippe
Jul 02, 2025Aspirant
MS305E Invalid password when accessed through DNS name instead of IP
I just configured a new MS305E. When I access the UI through it's IP address (http://10.10.1.5), everything works correctly. When I access the UI through a DNS Name (http://switch1.home), I get the...
schumaku
Jul 04, 2025Guru - Experienced User
Afraid, I don't own an MS305E (nor a MS308E), so can't compare. On the GS308EPP, defining the device name does not make a difference, it can be reached and accessed using the password either way.
As we haven't seen active moderators in these community sections since the big update, and your MS305E is new, don't hesitate to contact the formal Netgear support via https://my.netgear.com/
This is definitively an unexpected behaviour, suspect a bug.
schumaku
This DNS name is served by the ISP router LAN btw. - works like using the pure lan IP address.
