alexatkin
Apr 09, 2023Aspirant
MS510TXUP WebUI randomly stops working
I have had this happen a couple of times now where the WebUI will just suddenly not respond. Today for the first time I noticed the power LED is also flashing quickly on the switch, possibly to noti...
NiveditaP
Apr 26, 2023NETGEAR Employee Retired
Hello,
If there is no error found in the state of the switch, then the reason for the LED blinking also might be because of the duplex mismatch. So check the duplex speed
Also, check for the color of the LED.
Another possible reason might be A network loop (redundant
path) might be created.
If the web UI is not responding check for the compatibility of the browser and clear all the cache and check again. Also, check for the application whether you can able to access it from there.
If your issue is resolved please close the thread by clicking "Accept as solution".
Have a lovely day,
Nivedita Pa
Netgear Team
- alexatkinApr 26, 2023Aspirant
Its the power LED flashing and all network connectivity operates as normal, just the WebUI not functional, ping and SSH still work. Is there a way to manually restart the WebUI via the SSH console?
What application did you mean for checking? I have no intention of enabling Insight if that's what you mean as I rarely need to make any changes and all monitoring is done over SNMP.
