alexatkin
Apr 09, 2023Aspirant
MS510TXUP WebUI randomly stops working
I have had this happen a couple of times now where the WebUI will just suddenly not respond. Today for the first time I noticed the power LED is also flashing quickly on the switch, possibly to noti...
schumaku
Apr 26, 2023Guru - Experienced User
The MS510TXUP physical power LED can blink (fast) green while the switch is restarting. This status isn't visible in the Web based Device View.
Flashing could indicate a crash or restart situation.
alexatkin
Apr 27, 2023Aspirant
The only thing that could have crashed is the WebUI/server itself as all switch functionality operates normally. I've left it in this state for days as obviously rebooting a switch is a pain when its in active use.
So far I've had to power cycle which is a huge pain given then I have to wait for all my PoE devices to reboot too. If I can soft reboot from SSH it would be more practical as I have permanent PoE power enabled so it wouldn't power cycle the connected devices. Even better would be recognising there is an issue here and fix it in firmware.
Its not a cheap switch and I'm fairly sure this only started happening after the last firmware. I assume booting to an older firmware retains settings? For now I've enabled remote syslog, see if it reports anything the next time it happens.
