alexatkin
Apr 09, 2023Aspirant
MS510TXUP WebUI randomly stops working
I have had this happen a couple of times now where the WebUI will just suddenly not respond. Today for the first time I noticed the power LED is also flashing quickly on the switch, possibly to noti...
alexatkin
Apr 27, 2023Aspirant
The only thing that could have crashed is the WebUI/server itself as all switch functionality operates normally. I've left it in this state for days as obviously rebooting a switch is a pain when its in active use.
So far I've had to power cycle which is a huge pain given then I have to wait for all my PoE devices to reboot too. If I can soft reboot from SSH it would be more practical as I have permanent PoE power enabled so it wouldn't power cycle the connected devices. Even better would be recognising there is an issue here and fix it in firmware.
Its not a cheap switch and I'm fairly sure this only started happening after the last firmware. I assume booting to an older firmware retains settings? For now I've enabled remote syslog, see if it reports anything the next time it happens.
schumaku
Apr 28, 2023Guru - Experienced User
Operating a bunch of MS510TXUP (v10.0.5.12 since late March, a hand full in local admin, most in Insight cloud mode) along with a few MS510TX and MS510TXPP (v6.7.0.52 since last summer). Web UI remain available reliably here, in either way. All covered in syslog monitoring, nothing uncommon visible.
Just curious, are your switches Web UI exposed to the wild Internet or a target for possible attacks or IDS scans?
