alexatkin
Apr 09, 2023Aspirant
MS510TXUP WebUI randomly stops working
I have had this happen a couple of times now where the WebUI will just suddenly not respond. Today for the first time I noticed the power LED is also flashing quickly on the switch, possibly to noti...
TauntaunSteakum
Dec 08, 2023Aspirant
Just happened to me on MS510TX, https login successful but only partial webui load. Some panels showing connection refused test instead. Logged out, power cycled, and now Chrome gives:
This site can’t be reached
192... refused to connect.
..and Firefox gives:
Unable to connect
An error occurred during a connection to 192...
Tried ssh and recieved:
ssh: connect to host 192... port 22: Connection refused
Should I factory reset? ..what a pain..
- schumakuDec 09, 2023Guru - Experienced UserDoes the https://www.netgear.com/support/product/netgear-switch-discovery-tool#download confirm you talk to the switch you intend to administer?
- TauntaunSteakumDec 09, 2023Aspirant
Great idea! ..Nothing found though.
Time for a factory reset and retry...
