PeterG10's avatar
PeterG10
My Netgear POE switch FS728TP is on but no POE activity
I had 2 of these switches for several years working fine! I just discovered that though the switch is on including the lights of the POE it still does not provide any POE activity when I plug in a device. When I tried to reset the switch all the lights do come on in the top part but still nothing works! Could it be that POE has a fuse that blew? Appreciate your feedback!
1 Reply
  • schumaku's avatar
    schumaku
    This pushbutton allows to change the logical display if the relevant LED on each port only, the LED mode LED indicates the mode only.
    Suspect the PoE controller or the relevant power supply might be broken.
    Head to https://my.netgear.com
    for your FS7yx model and serial number warrant terms.
ProSupport for Business
