Irritator
Feb 11, 2026Aspirant
Netgear Discovery tool 2.0.7.0 no longer finding my 5 switches.
I have used the utility many times before. Sometimes I have to run it twice to get results. Now it doesn't find anything. I can ping them all by IP, I can get into them via web and they are all...
Feb 12, 2026Guru - Experienced User
If you have internet security or antivirus software running on the PC, try disabling that and see if that resolves the issue.
- IrritatorFeb 12, 2026Aspirant
Thank you for the reply StevenB. Yes, I should've mentioned that I did disable antivirus and firewall and still had no results.
- StephenBFeb 12, 2026Guru - Experienced User
Another thing you might try is connecting the PC with ethernet instead of WiFi.
The discovery method uses a broadcast protocol, and sometimes the router doesn't forward the broadcast packets across different network segments (e.g., wifi <-> ethernet).
Power-cycling the switches is another thing you might try.
- schumakuFeb 12, 2026Guru - Experienced User
Afraid, this is wrong, appears you still think in the old NSDP ways... (Wiki:
Netgear Switch Discovery Protocol ).
NDT is making use of SSDP, which is based on (Wiki:
Simple Service Discovery Protocol ), multicast addressing to a specifically designated IP multicast address at UDP port number 1900. In IPv4, the multicast address is 239.255.255.250, and SSDP over IPv6 uses the address set ff0x::c for all scope ranges indicated by x.
StephenB, I guess I should've mentioned that too. I am wired directly to the 8 Port in dining room GS108EV4 which is wired directly to the other 4 switches.
My other utility fines the switches by MAC just fine from the same computer. I don't think it's a broadcast protocol issue.
I did power cycle the switches.
Attached is a copy of the NGDT output, and my ping scanner output.
