UsmanAnwar's avatar
UsmanAnwar
Netgear FS728TP switch issue (POE)
Hello, i am facing a weired issue in netgear switch Model FS728TP. If i connect my CCTV workstation with netgear switch it start freezing my multicast feed and after 10 minutes my workspace becomes b...
  • Napsterbater's avatar
    Oct 22, 2015
    I would check IGMP Settings on the switch if enabled try disabling it Globaly and on the VLAN and Ports.
    Also check/disable (set untrusted for global) the QOS/COS and DiffServ settings.
    Another thing to check/try is Storm control Under Security -> Traffic Control, make sure its disabled.
ProSupport for Business
