HBrouwer
Aug 01, 2025Tutor
Netgear GS105e mismatch
Starting the cable tester it gives a mismatch (Cable Fault Distance 6 meters) at port 1. The other cables are OK. After replacing the networkcable between the switch and my router (Sagemcom F3896LG...
- Aug 04, 2025
Yes. Port 4 was the problem. Now 2 x Netgear GS 105ev2 at Ports 1 and 3 of the router and 1x Netgear GS108ev4 at port 4 of the router. Port 2 of the router one cable directly to a computer. Now everything works without mismatches.
thanks for hor help.
schumaku
Aug 04, 2025Guru - Experienced User
...on the router side from what I understand.
Unless I'm wrong, three are plain GbE ports, and the fourth is a 2.5 GbE MultiGig port.
Is this the one where the simple test goes wrong?
The cable test can show incorrect results under some non-standard conditions, and works on specific cables, and against a simple GbE port only.
HBrouwer
Aug 04, 2025Tutor
