Pleasefix
Feb 05, 2026Aspirant
Netgear GS105Ev2 mismatch
Hello, Since the past couple of days, I encountered a problem where a number of applications and websites are not working properly. Sometimes they do, sometimes they don't. For example, on twitch...
Pleasefix
I've also tried to use different ports for my pc, but they also show a Mismatch when plugged in.
- StephenBFeb 05, 2026Guru - Experienced User
Are you saying using Port 5 on the switch instead of Port 2 gives the same error?
Pleasefix wrote:
I've tried 3 different cables, where each one shows a Mismatch at the end of the cable.
What grade is the cable? Does it run directly to the PC, or is there a junction box or patch panel along the path?
- PleasefixFeb 05, 2026Aspirant
Yes, it gives the same error. So does port 3 and 4.
I've tried cables ranging from CAT5e and CAT6.
Thanks!
It runs directly from the switch to my PC. There are no junction boxes or patch panels along the path.
