Pleasefix
Feb 05, 2026Aspirant
Netgear GS105Ev2 mismatch
Hello, Since the past couple of days, I encountered a problem where a number of applications and websites are not working properly. Sometimes they do, sometimes they don't. For example, on twitch...
Pleasefix
I've also tried to use different ports for my pc, but they also show a Mismatch when plugged in.
Feb 05, 2026Guru - Experienced User
Pleasefix wrote:I've also tried to use different ports for my pc, but they also show a Mismatch when plugged in.
Are you saying using Port 5 on the switch instead of Port 2 gives the same error?
Pleasefix wrote:I've tried 3 different cables, where each one shows a Mismatch at the end of the cable.
What grade is the cable? Does it run directly to the PC, or is there a junction box or patch panel along the path?
- PleasefixFeb 05, 2026Aspirant
Yes, it gives the same error. So does port 3 and 4.
I've tried cables ranging from CAT5e and CAT6.
Thanks!
It runs directly from the switch to my PC. There are no junction boxes or patch panels along the path.
- StephenBFeb 05, 2026Guru - Experienced User
Do you see the same error if you connect one of these cables to another ethernet device?
I am wondering if it might be the socket in the PC.
I don't see the same error.
This is what I was wondering as well. As nothing has changed, hardware of software-wise) between it working properly (2 weeks ago) vs now.
That doesn't quite explain the same errors on the same applications/websites though. As those are quite consistent. Whereas other websites have no issue at all. For example, discord keeps working even though it's also live data with no buffer.
