GeoffCoope
Aug 21, 2016Aspirant
NETGEAR GS110TP - Ports failing - no light on 1st port after 24 hours, no light on 2nd after 24 hour
Hi, we bought this 8 port PoE switch at the end of June and have just got around to installing it into our home. https://www.amazon.co.uk/dp/B00MHLUS8E/ref=cm_cr_ryp_prd_ttl_sol_0 Everything work...
JohnRo
Aug 23, 2016NETGEAR Employee Retired
Hello GeoffCoope,
Welcome to the community!
You can probably try initiating a "Factory Reset", push and hold the factory reset button on the front of the switch. There should be some activity on the front lights or the power led when doing so. Can you PM me a picture of the bottom part of the switch where the serial number, mac, etc. is printed?
Thanks,
