GeoffCoope
Aug 21, 2016Aspirant
NETGEAR GS110TP - Ports failing - no light on 1st port after 24 hours, no light on 2nd after 24 hour
Hi, we bought this 8 port PoE switch at the end of June and have just got around to installing it into our home. https://www.amazon.co.uk/dp/B00MHLUS8E/ref=cm_cr_ryp_prd_ttl_sol_0 Everything work...
JohnRo
Aug 24, 2016NETGEAR Employee Retired
Hi Geoff,
Let us know what happens after the factory reset. I have checked the serial number on our system and it indeed shows as a v2 unit. If the issue will still continue after the reset, I suggest filing a ticket for RMA.
Thanks,
GeoffCoope
Aug 24, 2016Aspirant
Will do that this evening and let you know. Thanks for the support.
Geoff
