Vimes
Aug 27, 2024Apprentice
NETGEAR GS110TP-200EUS ProSAFE 8-Port switch probable fault one port
Hi I have had this managed switch for many years. Now it is used to supply POE for a number of CCTV cameras only. The typical power usage.... can be seen above. The software / firmwa...
Aug 29, 2024Guru - Experienced User
Have you swapped around what is connected to port 6 with a different PoE device to see if same thing happens with a different device connected to port 6?
Swap out LAN cabling? CAT6 would be recommended.
Has a factory reset and setup from scratch been tried?
Vimes
Aug 29, 2024Apprentice
Thanks. External grade CAT 6 cabling used throughout. Devices swapped and POE switch factory reset.
I gave up with that POE Switch now, it was becoming redundant due to its low overall power output compared to what now can be bought.
To replace it is a Netgear GS308EPP switch with an overall 123w capacity.
The venerable previous switch will be retired from POE usage.
In some ways the information offered from the UI of the newer switch is worse than that of the older one...!
Newer is not always better, in every way...!
Thanks again for your reply.
- FURRYe38Aug 29, 2024Guru - Experienced User
Good luck and enjoy.
- RennaDAug 29, 2024NETGEAR Moderator
Hello Vimes,
If you are pertaining to the features of your new switch, then this is because the GS308EPP is a Plus switch which has less features compared to the GS110TPv2 which is a Smart managed switch.
Have a lovely day,
RennaD
Netgear Team- VimesAug 29, 2024Apprentice
Thanks. Whilst I can appreciate the product segmentation, there has been a long time between the production of the previous model and that of the one I have just bought to replace it with.
Putting aside differences in other areas I'll just comment on the POE side...
Albeit written in Java, that failed to work and was not address in the previous model due to security (?) issues with the old version used, it was great to have a pictorial representation of the ports, connections and power etc.
You also would get information on the total threshold power, and then the power used overall in watts.
So far I can't see a way to show the cumulative power used by the latest model across all ports. Just a way to gather information myself of the wattage used on each port and then need to add these together.
They are both managed switches, but I could not find anything being sold by Netgear being available in the same class and total power output similar to the one I bought.
- RennaDAug 30, 2024NETGEAR Moderator
Hello Vimes,
Thank you for the comment. I checked this but I did not see any Plus switch that has Device View and Consumed Power information on the UI. On the other hand most if not all of the Smart switches has this. You may want to check the GS510TPP — 8-Port Gigabit High Power PoE+ Smart Switch with 2 SFP Ports (190W).
https://www.downloads.netgear.com/files/GDC/GS418TPP/GS418TPP-GS510TLP-GS510TPP_UM_EN.pdf
Device View - Page 25
Consumed Power - page 81
Have a lovely day,
RennaD
Netgear Team
