livefastdrvslo
Nov 25, 2018Aspirant
netgear gs724t crash when router connected
i just got a netgear GS724t v3 24port switch and reset it to factory defaults. so now i don't understand why when i connect the switch to the router the switch just decides to light up the entire bo...
- Nov 26, 2018
Hi livefastdrvslo,
Welcome to the community! :)
The current firmware of your GS724Tv3 switch is the initial release firmware. I suggest you to upgrade the firmware in a ladderized manner. First, upgrade the firmware from v4.1.0.9 to v4.2.0.11. Then, upgrade the firmware from v4.2.0.11 to 4.2.1.5 and so on until you reach the latest firmware version which is 5.4.2.30.
Be sure to perform a factory reset after upgrading the firmware to the latest version then reconfigure the settings from scratch in order to start clean using the latest firmware version. Then check if the same problem occurs.
You can download the firmware versions for the GS724Tv3 switch here.
DaneA
NETGEAR CommunityTeam
DaneA
Nov 26, 2018NETGEAR Employee Retired
Hi livefastdrvslo,
DaneA
- livefastdrvsloNov 26, 2018Aspirant
thank your sir!....whatever that firmware flash did it fixed the issue. as soon as i did the first one it played ok with the router connected..... such a simple fix....
i'll slowly work my way up to current firmware now.
