Gareth53
Apr 25, 2021Aspirant
New Router connected to 24 port Gigabit Ethernet PoE + Smart Managed Pro switch with 2SFP Ports
Hi, We live in the country and have to rely on mobile broadband. I have just been forced to change router by my mobile braodband supplier. The old router (HH70VB) had no trouble in connecting throug...
JohnC_V
Apr 29, 2021NETGEAR Employee Retired
Welcome to our community! :)
There could be a loop in your network that is causing your switch to crash. May I know the model number of your switch? You may also try enabling the STP of your switch in order for us to determine if there is a loop on your network. Please make sure that the switch is connected directly to the router.
John
NETGEAR Community Team
- Gareth53Apr 30, 2021Aspirant
Hi,
Thank you for your reply.
The model number for the switch is GS724T and yes the switch is connected directly to the router.
If I link the router directly to the computers, they work fine too. It is annoying as the old router worked fine through the switch although it had difficulty picking up the mobile signal. The new one gets a great signal but just will not work with the switch.
Cheers Gareth
