Hyrrican
Apr 21, 2024Tutor
No DHCP on NETGEAR GS316EP via FritzBox
Hi all, I have a issue with my GS316EP (Firmware 1.0.3.7), if I am connecting it directly to the FritzBox the switch doesn't get any IP address from the FritzBox, the DHCP is marked as active: ...
- May 05, 2024
Hi Kurt,
FS hat das Modul zurück genommen und das 1 GB-Modul funktioniert jetzt, danke nochmal für die Hilfe.
schumaku
Apr 22, 2024Guru - Experienced User
Some FritzBoxes can be configured so some LAN ports are connecting to different networks, like Guest or assigned to an IPTV network.
Start with the GS316EP connecting to the GS110EMX (assuming it's on the default config and no other VLANs are in use), cold boot it (power cable off and on), then head to https://www.netgear.com/support/product/netgear-switch-discovery-tool/#download to download, install the Netgear Switch Discovery tool for your computer (Windows, Mac, Linux, ...) and launch it. Convinced both switches can be discovered.
