Hyrrican
Apr 21, 2024Tutor
No DHCP on NETGEAR GS316EP via FritzBox
Hi all, I have a issue with my GS316EP (Firmware 1.0.3.7), if I am connecting it directly to the FritzBox the switch doesn't get any IP address from the FritzBox, the DHCP is marked as active: ...
- May 05, 2024
Hi Kurt,
FS hat das Modul zurück genommen und das 1 GB-Modul funktioniert jetzt, danke nochmal für die Hilfe.
Hyrrican
Apr 22, 2024Tutor
Hi,
the tool is working, but I have only access via the static address, the switch doesn't get an ip address assigned from the FritzBox, thanks.
Now I have another problem, I have connected the GS110EMX with the 10GB/s port to the GS316EP 10GB/s SFP RJ45 modul, but I get no connection (only 1,5 meter CAT7 cable), link LED on GS110EMX says all good. If I now connect the GS110EMX 10GB/s port with only one of the 1 GB/s ports of the GS316EP connection is working, what is the problem on the SFP 10GB/s port, is there a difference between the plugin modules?
Hyrrican
Apr 22, 2024Tutor
Hi,
switch got now ip address after some time from the FritzBox, I don't know why it takes more then 30 minutes. I also found out that Netgear switches needs a AXM765 10GB/s RJ45 compatible modul, will see if this helps and solve my issue.
Br Hyrrican
- schumakuApr 22, 2024Guru - Experienced User
Hi
Most plus switches have a non-sopisticated dhcpd client. Don't know exactly fo the subject GS316EP, Mo's Plus switched are built on a non-managed core switch and tiny 8051 class uC handling dhcpcdand the IGMP multicast controls. This dhcpcd tends to time out very quickly if not receiving an answer from the DHCP server in time, tend to say max 30 seconds - then the default IP address is activated. So hard to believe this could really take such a long time, because the uC does not retry the DHCP process.
To avoid troubles with the 10Gb SFP+ ports -.start with a 1 GbE port for the connection.
In my ad-hoc test scenarios, I've found some no-nane SFP+ nicely work connecting to 10GbE ports, and typically also GbEports.
Avoid to much variables, and k3p things simple.
Are you native German speaking btw? We coru communicate also in German in case.
Afraid, you still have not told us which FritzBox model you are using, and if some of the ports mih be configured for IPTV or a guest network.
Regards
-Kurt,
- HyrricanApr 27, 2024Tutor
Hi Kurt,
gern auch auf Deutsch, ich habe eine FritzBox 5590 Fiber dran, aber kein IPTV. Der normale 1 GB/s-Port geht. Leider geht das neue gelieferte AMX765 Modul auch nicht, obwohl der GS110EMX den Link anzeigt, verstehe leider nicht warum dass so ein Problem für den Switch ist.
Gruß Mathias
- schumakuApr 27, 2024Guru - Experienced User
Du erwartest die Möglichkeit den SFP/SFP+ port im 5590 als reines LAN port zu betreiben?
Oder dann doch als WAN (GPON, usw.)? Das gibt dann nur die Möglichekeit den WAN-Link dort zu betrieben, GPON usw kann der Switch ja kaum. Was erwartest Du dann von diesem kleinen Switch genau? Mache doch bite eine einfache Zeichnung - von Hand als BIld reicht durchaus.
Finde auf die Schnelle auch nichts, wie man des Fiber-port am 5590 als LAN Port betreiben kann.
Grüsse
-Kurt.
