Jenjo's avatar
Jenjo
Only One GS108Tv2 Recognizes Gigabit Connection to Playstation 4
Hey!
I'm kind of going nuts trying to figure this one out. Here's what I've got:
Gateway (NVG599, no choice, required by ISP) > Switch 1 (GS108Tv2) > Switch 2 (also a GS108Tv2) > Playstation 4
Internet: AT&T Fiber, tests at the full gig (or as close as it gets) on my PC
Cables: All cat 6 or Cat5E
My husband has been complaining of poor speeds on the PS4. Our other devices on the second switch aren't gigabit capable, so they don't really indicate slower connections than they should. I replaced the cable between Switch 2 and the PS4 and Switch 2 began recognizing it as a gigabit connection. I checked the speeds, they'd gone up to 74 mbps down, but from what I can tell it should be capable of at least 250 (PSN doesn't likely allow much faster than that, so my aim isn't too high). I checked Switch 2 and it shows the PS4 port and the connection to Switch 1 as a gigabit connection. I checked Switch 1 and it shows a gigabit connection to Switch 2 but only 100 for the PS4 port, no option to set it to 1000 manually. I've rebooted, I've Googled, I've put both the PS4's mac address in what passes for a DMZ with out gateway, and I'm at a loss for anything else to try at this point. Most things like this seem to be cable problems, but Switch 2 shows a gigabit to the device and both switches show a gigabit connection to each other.
Any suggestions?
  • Hey!
    Thank you for following up. I'm sorry I haven't replied sooner; I don't have much time during weekdays and ended up discovering a few things.
    -You are correct in your reiteration of the network path to the PS4.
    -I switched around all the cables over the weekend and when I switched them back to what they were, the PS4 was suddenly receiving appropriate speeds. It's still showing as not a gigabit connection on the other switch, but since it's not actually limiting anything it's not really a worry anymore.
    -When switching the cables around, I found a bleeping keystone in the cable leading outside for not apparent reason. Since my husband's other keystone installations didn't work out so well over time, this is a giant red flag.
    -Apparently my husband switched out the Belkin switch we had on our Tivo in the bedroom with yet another Netgear GS108T, so I now have to go through and check the mac address on the first switch in the link to verify whether it's the one I've actually been looking at or if I've been connecting to a third one I didn't even know we had to try and work all this through.
    Either way, the PS4 is no longer limited to like 54 megs, so we're good!
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Jenjo,
    Welcome to the community! :)
    Kindly answer the questions below:
    a. Just to confirm, the PS4 port connected to Switch 1 shows a Gigabit connection.  Then, the PS4 port connected to Switch 2 just shows 100Mbps.  Lastly, the connection between the 2 switches shows a Gigabit connection.  Am I right?
    b. What is the current firmware version of both GS108Tv2?
    DaneA
    NETGEAR Community Team
    • DaneA's avatar
      DaneA
      Jenjo,
      I just want to follow-up on this.
      DaneA
      • Jenjo's avatar
        Jenjo
        Hey!
ProSupport for Business
