itplustech
Nov 19, 2016Aspirant
port 25 on GS724Tv4 keeps shutting down
Hi Need some help! We have a fibre link between 2 offices. Office 1 has a GS724Tv4 smart managed Switch and Office 2 has a JGS516 unmanaged switch with a fibre media converter. since 2 days ag...
- Nov 23, 2016
Apologies for the delay. Had to eventually go oniste.
Problem was that some champion decided to loop a cable into a small 5 port switch
Removed and problem solved
itplustech
Nov 23, 2016Aspirant
DaneA
Nov 23, 2016NETGEAR Employee Retired
I'm glad that you were able to figure it out and resolved the problem. :)
Since the problem has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
