FreemanMusiz
Sep 10, 2018Guide
Port connected to router randomly becomes disabled
I have had this switch for about three months now, it works well expect that the port connected to router would randomly becomes disabled.
The router assigned 192.168.1.100 to the switch, which...
- Sep 18, 2018Sorry for that issue, but it seems that a constant DoS attack propagating from the router is mitigated by the switch with either Auto-Dos feature (please configure it here: System Management Denial of Service Auto-DoS Configuration.) or DoS configuration feature (please configure it here: System Management Denial of Service Denial of Service Configuration.).
Maybe because of your NAS services accessible from the internet or a Dos attack against your router, the switch is trying to protect your network. Please can you test and de-activate Auto-DoS in above GUI page, and ultimately configure DoS differently in the other GUI page and let the Community know the results?
JohnC_V
Sep 11, 2018NETGEAR Employee Retired
Hi FreemanMusiz,
Welcome to our community! :)
Please make sure that the switch is running on its latest firmware. Have you tried to isolate the issue by moving it to the other ports?
You may download the latest firmware here.
- FreemanMusizSep 11, 2018Guide
Hi JohnCarloV,
Actually, I had opened a case with Netgear support before. So we have gone through the typical steps of troubleshooting, include updating to the latest firmware, chaging cable, changing ports, factory reset/reimport settings. However, none of that worked.
In fact, one workaround I have been using is just moving the cable from the router to another open port, but then after a while that port would become disabled as well. So, I will have to reenable in the console or soft/hard restart the switch.
The Netgear support was very unhelpful, as they just blame our router for being the issue and throw their hands in the air. Hence, I have create this thread to get help from the community.
Cheers,
John
- schumakuSep 11, 2018Guru - Experienced User
Hi John,
Is there potentially a loop from the other network/network devices connected to the XS for example to the router or another wireless, for example by some media player?
What does the XS log show about the reason for the uplink port becoming disabled?- FreemanMusizSep 11, 2018Guide
Hi schumaku,
Initially, when we worked with support, they found the log to be reporting discarding Invalid BPDUs, so they recommended us to disable spanning tree. It did get rid of the errors in the log, however, this did not resolve this issue.
Please see attached our network topology. It's quite simple, not sure why the loop might be. One thing to note is that our new NAS, the Synology DS3617XS has DDNS setup (ports forwarded in the router), so it is accessiable through the internet.
I don't have access to the switch right now, but once I do, I will share the log.
Thank you in advance.
Cheers,
John
