Rajstopy
Jan 18, 2022Aspirant
Port GigabitEthernet2 moving from Disabled to Blocking
Dear all,
I already posted about the same issue some time ago, but still present in my logs as you can show. I notice a bunch of such messages always on the same port.
Can someone give me a clue, about what bould be the reason?
<182>1 2021-12-21T14:55:36.654Z 192.168.10.28-1 LLDP-6-NEIGHBOR_DISCOVER proto_lldp.c(5184) %% New neighbor on port GigabitEthernet1: Chassis ID F0:2F:74:1F:45:B3, Port ID F0:2F:74:1F:45:B3 <182>1 2021-12-21T14:27:00.924Z 192.168.10.28-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet2 moving from Blocking to Forwarding <182>1 2021-12-21T14:26:58.924Z 192.168.10.28-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet2 moving from Disabled to Blocking <181>1 2021-12-21T14:26:58.724Z 192.168.10.28-1 TRAPMGR-5-PORT_LINK_UP ksi_snmp.c(232) %% Interface GigabitEthernet2 link up <182>1 2021-12-21T14:26:55.924Z 192.168.10.28-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet2 moving from Blocking to Disabled <181>1 2021-12-21T14:26:55.824Z 192.168.10.28-1 TRAPMGR-5-PORT_LINK_DOWN ksi_snmp.c(230) %% Interface GigabitEthernet2 link down <182>1 2021-12-21T14:26:54.924Z 192.168.10.28-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet2 moving from Disabled to Blocking <181>1 2021-12-21T14:26:54.744Z 192.168.10.28-1 TRAPMGR-5-PORT_LINK_UP ksi_snmp.c(232) %% Interface GigabitEthernet2 link up <182>1 2021-12-21T14:26:51.924Z 192.168.10.28-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet2 moving from Forwarding to Disabled <181>1 2021-12-21T14:26:51.834Z 192.168.10.28-1 TRAPMGR-5-PORT_LINK_DOWN ksi_snmp.c(230) %% Interface GigabitEthernet2 link down <182>1 2021-12-21T14:26:32.924Z 192.168.10.28-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet2 moving from Blocking to Forwarding <182>1 2021-12-21T14:26:29.924Z 192.168.10.28-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet2 moving from Disabled to Blocking <181>1 2021-12-21T14:26:29.894Z 192.168.10.28-1 TRAPMGR-5-PORT_LINK_UP ksi_snmp.c(232) %% Interface GigabitEthernet2 link up <182>1 2021-12-21T14:26:26.924Z 192.168.10.28-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet2 moving from Blocking to Disabled <181>1 2021-12-21T14:26:26.794Z 192.168.10.28-1 TRAPMGR-5-PORT_LINK_DOWN ksi_snmp.c(230) %% Interface GigabitEthernet2 link down <182>1 2021-12-21T14:26:25.924Z 192.168.10.28-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet2 moving from Disabled to Blocking <181>1 2021-12-21T14:26:25.844Z 192.168.10.28-1 TRAPMGR-5-PORT_LINK_UP ksi_snmp.c(232) %% Interface GigabitEthernet2 link up <182>1 2021-12-21T14:26:23.174Z 192.168.10.28-1 STP-6-PORT_STATE proto_stp.c(820) %% Port GigabitEthernet2 moving from Forwarding to Disabled
Wonky link, wonky cable, wonky peer adapter/system - link going down and up. Link seems to be bouncing under some unknown conditions.
No STP variant does ever take the physical Ethernet link down.
Also strange, the last LLDP new neighbor almost 30 minutes after the link came up. Here I could admit that this might be from a VM or the link bridged to that other adapter on the far end.
Same issue on all ports, or just the #2?
PS. Requesting a moderator to move this thread to the appropiate "Smart Plus And Smart Pro Managed Switches Forum" community section.
- RajstopyAspirant
Thank you very much for your answer, very appreciated.
Actually I experience this behavior only on one port. This port is linked to my ESXi management NIC so I don't understand why a VM could be involved.
I must admit I'm a little bit lost.
Cheers,
Already moved the ESXi link to a different port on the switch?
The bouncing link should be visible on the ESXi host, too.
