tony_luv's avatar
Mar 14, 2016
Printing From iPad
hi ipad not finding network printer, using ipad wifi, vmdg490, fvs318gv2, gs724tv4 then hp officejet pro 9610 network printer. can someone help? tony.
  • JohnRo's avatar
    JohnRo
    Mar 23, 2016
    Hello tony_luv,
    Glad you got it working! :) You can also find documents on our support site that will help you learn more about the FVS318G, please click here for the manual.
    If one of my posts helped you fix the issue, please mark it as a solution this will help other members of our community if they experience the same problem.
    Cheers,
ProSupport for Business
