tony_luv
Mar 14, 2016Tutor
Printing From iPad
hi ipad not finding network printer, using ipad wifi, vmdg490, fvs318gv2, gs724tv4 then hp officejet pro 9610 network printer. can someone help? tony.
- Mar 23, 2016
Hello tony_luv,
Glad you got it working! :) You can also find documents on our support site that will help you learn more about the FVS318G, please click here for the manual.
If one of my posts helped you fix the issue, please mark it as a solution this will help other members of our community if they experience the same problem.
Cheers,
tony_luv
Mar 22, 2016Tutor
hi the dhcp is turn off, the ipad works on the moduem ok, but it will find the printer, if take the firewall out its ok with the switch.
ipad ip 192.168.0.17
printer ip 192.168.1.5 when the firewall is in place.
JohnRo
Mar 22, 2016NETGEAR Employee Retired
Hello tony_luv,
See the difference between the IP addresses of the iPad and the printer, they belong to two different networks. What is happening here is you have two DHCP servers, the modem and the firewall. The FVS318Gv2 when connected to the modem, creates its own network (which its supposed to do). The printer is connected to the firewall's network and the iPad is connected to the modem's network, which is why they are not communicating. What you can do is 1. Configure the Firewall as a switch (this will eliminate NAT and Firewall functions) or 2. Disable the router function of the modem (make it a basic modem, this will disable the wi-fi) and get an Access Point and the connect it to the Firewall.
Let us know if you have more questions.
Thanks,
