tony_luv
Mar 14, 2016Tutor
Printing From iPad
hi ipad not finding network printer, using ipad wifi, vmdg490, fvs318gv2, gs724tv4 then hp officejet pro 9610 network printer. can someone help? tony.
- Mar 23, 2016
Hello tony_luv,
Glad you got it working! :) You can also find documents on our support site that will help you learn more about the FVS318G, please click here for the manual.
If one of my posts helped you fix the issue, please mark it as a solution this will help other members of our community if they experience the same problem.
Cheers,
tony_luv
Mar 23, 2016Tutor
hi
thanks for reply
i have manged to set ipad and printer in hp eprint mod and it works i can send work to the printer that way..... thanks for your help, i am waiting for a book on firewall and hope to learn more about it :smileyhappy:
thanks again tony.
JohnRo
Mar 23, 2016NETGEAR Employee Retired
Hello tony_luv,
Cheers,
