bluefoot
Oct 03, 2016Aspirant
Problems connecting Netgear XS748T to Ubiquiti UniFi US-48-750W via SFP+ Port
We purchased a new Netgear XS748T switch and are trying to connect it to our existing network that consists of several Ubiquiti UniFi US-48-750W switches and we are trying to connect them using the 1...
- Oct 07, 2016
It appears that I solved the problem myself. I purchased a set of:
10Gtek for Cisco SFP-10G-LR, 10Gb/s SFP+ Transceiver module 1310nm, 10kmAnd the LR version worked instantly. I honestly don't know what the difference is between an SR SFP+ module and an LR SFP+ module but for whatever reasons the LR module allowed these two switches to connect.
Here are links to the modules and cable used in case anyone else needs a solution to this:
LR SFP+ Module:
https://www.amazon.com/gp/product/B00UMS905G/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1Fiber cable:
https://www.amazon.com/gp/product/B00T5796DQ/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
LaurentMa
Oct 04, 2016NETGEAR Expert
Hi bluefoot
We need to troubleshoot this incompatibility.
Would you provide us with what is displayed in Port Configuration table for that given port in XS748T?
(Switching > Ports > Port Configuration)
Then provide us with the content from Port Statistics for that port (Monitoring > Ports > Port Statistics).
And finally Detailed Port Statistics for that port as well (Monitoring > Ports > Port Detailed Statistics).
If you prefer, we can also open a case at Technical Support and remotely log into your installation.
We are taking interop issues very seriously and we are going to procure this Ubiquiti switch as well. But let us know how best we can help you right now.
bluefoot
Oct 05, 2016Aspirant
Can you provide instructions on how to send you the information you need? Also I have a support ticket open now support case #27493151
- LaurentMaOct 05, 2016NETGEAR Expert
Thank you. Now that you have Technical Support opened case, we are going to take it simply from there.
After the troubleshooting, we will recapitulate actions taken and output here in this ticket, so that it can serve the Community.
- bluefootOct 07, 2016Aspirant
LR SFP+ Module:
https://www.amazon.com/gp/product/B00T5796DQ/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1- JohnRoOct 07, 2016NETGEAR Employee Retired
Hi bluefoot,
I'm glad that you issue is now sorted out. The problem may be from the older SFP modules that you have, probably compatibility? I encourage you to mark your post above as "Accept as Solution". So others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
