manlymanagement's avatar
Feb 03, 2017
Prosafe Plus GS116Ev2 VLAN trunking
Hi, I would really appreciate help finding the name for the feature and where I can read regarding configuration.
I require to set up VLAN trunking, forwarding the tag from source to destination and not removing.
http://www.ciscopress.com/articles/article.asp?p=29803&seqNum=3
Is this done by adding multiple VLAN membership to a single port? Is this feature availalbe?
Thanks again for your help.
  • Hi Kc1
    You have to first configure the Switch to use 802.1Q Advanced VLAN, once you do this you should be able to see the Untag and Tag
    Regards
  • XavierLL's avatar
    XavierLL
    NETGEAR Employee Retired
    HI Manlymanagement,
    Welcome to our community!
    To set up a VLAN trunking in our GS116E you are right you have to add the VLANs to VLAN Membership, please find below the three steps required:
    1. Create the VLANs
    2. Use VLAN Memberships to add the VLANs to the Trunk Port ( you have to mark them with T)
    3. Check that the PVID for the trunk port is 1 ( this is the native VLAN)
    Moreover see an example in the following link
    Hope that it helps.
    Xavier Lleixa
    NETGEAR CBU PLM
    • Anonymous's avatar
      Anonymous
      XavierLL in the link that you gave, the example shows Tagging the connection/'trunk' between the 2 switches.  However, Prosafe Plus GS116Ev2 firmware does not seem to support marking ports as tagged or untagged, nor is there any way to set the PVID
      ...or am I missing something?
      • XavierLL's avatar
        XavierLL
        Hi Kc1
        Regards
ProSupport for Business
