fiscap
Jul 24, 2021Aspirant
ProSafe Plus JGS516PE - All Amber LEDs
I have a ProSafe Plus JGS516PE switch which has been working great for the last couple of years, however this morning we had no network throughout the house. In checking the JGS516PE, I noticed that ...
tmittelstaedt
Jul 27, 2021Star
Common symptom of failing power supply. If you cannot provide sales documentation or whatever else is needed in order to avail yourself of the free replacement lifetime warranty you might consider opening up the switch and looking at the large electrolytic capacitors on the power supply board, and if any of them are bulging/or split, replace ALL electrolytic capacitors on the supply board.
