ElectricSteve
Sep 29, 2016Aspirant
Prosafe S3300-28X - Real multi-chassis (stacked) LACP possible ?
Hello,
The Prosafe S3300-28X supports stacking up to 6 chassis. Is this stacking for pure management'purposes (all can be managed through 1 IP-address) or can I create LACP LAG's with ports fr...
- Oct 04, 2016
Hi ElectricSteve,
I am 100% positive the S3300 does true stacking, I've personally specified and installed these switches across numerous customer solutions, using LAG/LACP distributed across the stacked switches.
"S3300 True Stacking NETGEAR stacking feature provides resilient network architecture: up to six (6) S3300 switches can be stacked with a single management IP address, which simplifies network operations. VLAN and QoS can be managed in a unified fashion across the stack. Up to 288 Gigabit access ports and 12 available 10-Gigabit uplinks offer support for high-density developments as well as flexibility for future network expansion need. The S3300 architecture offers a 40Gbps bi-directional stacking backplane with built-in redundancy and auto-failover. The stacking capability allows for master and slave switches with a secondary master as back-up. The backup master can quickly take over the failed master switch function. Failed switches can be hot-swapped with the rest of the switches in the stack unaffected and operational. Please note that stacking is supported at 10-Gigabit speeds (with either 10GBASE-T Copper or SFP+ Fiber modules) only. 1G stacking is not supported."
What is stacking, which smart switches support it, and what are the functionalities of stacking?
S3300 Manual Page 64 Stacking Configuration
I hope that helps!
KieranP
Oct 03, 2016NETGEAR Expert
Hi ElectricSteve,
Welcome to community!
For sure you can acheive what you describe with the quoted switches.
With the S3300 you can stack with other S3300 models and as you said the unit's will operate as one virtual chassis, all connectivity will go to the master switch in the stack via its IP only, and all ports etc will now appear in the master GUI - you can then use LAG to connect out to the XS712T across multiple S3300 switches for redundancy. In this scenario on the S3300 stack you would bond the ports across switches.
That would look like this:
These guides should help with configuring the solution:
S3300 Manual Page 69 - Stacking Configuration
S3300 Manual Page 114 - LAG Configuration
What is stacking and what smart switches support it
I hope that helps, but dont hesitate to reach out if you need any more help.
Thanks,
JohnRo
Oct 03, 2016NETGEAR Employee Retired
Hello ElectricSteve,
On the hardware installation manual, it is indicated that ports 25-26 and 27-28 can also be used for stacking. This confirms that they can be used as regular ports or ports with LAG. I believe you should connect the 2 10G cables on only one of the S3300 switch only. First, confirm that the two S3300 are already on a stack and can be managed as a single unit. After that, configure the LAG to the XS712T.
Thanks,
