toilatoi71312
Jun 07, 2017Tutor
Rate limit option in GS748Tv5 and MAC static DHCP
Hi dear, I can't find the rate limit option in my GS748V5 same as here http://documentation.netgear.com/gs108t/enu/202-10337-01/GS108T_UM-07-05.html How I can limit rate by each port. And...
- Jun 12, 2017
Hi toilatoi71312,
Welcome to the community! :)
I will need to inquire your concern about Rate Limiting on the GS748Tv5 and I'll post here once I got a feedback.
About you other concern, as I understand it, you want to allow a specific MAC Address to have connectivity to a specific port on the switch, am I right? If ever I am right, kindly read about Port Security on pages 203-205 of the GS748Tv5 administration manual here.
DaneANETGEAR Community Team
DaneA
Jun 12, 2017NETGEAR Employee Retired
Hi toilatoi71312,
DaneA
toilatoi71312
Jun 12, 2017Tutor
Thank you dear,
I have find security port config in your guid. Thankyou so much.
As in administration manual, seem not have option of ratelimit (by kbps/speed)
Hope you can help me to config it.
Thankyou
- DaneAJun 13, 2017NETGEAR Employee Retired
I inquired your concern about Rate Limiting on the GS748Tv5 to the higher tier of NETGEAR Support and just got a feedback today. It was advised by the higher tier of NETGEAR Support to have Rate Limiting be logged as a feature request for the GS748Tv5.
With regard to this, I suggest you to post your concern as feature request on the Idea Exchange for Business board here. In this way, the development team can see what feature does GS748Tv5 users wanted to be added to the functionality of the switch.
DaneA
- toilatoi71312Jun 15, 2017Tutor
Dear DaneA,
Thank for your support.
With your answer, I had success fully to create specific MAC for port.
I also create an Idea Exchange for Business board/
Verry nice of support.
Thank you verry much.
