bignewf93
Aug 01, 2015Aspirant
Cannot access web management interface from a routed VLAN
 Model 4100 G12D Firmware 10.0.0.1.28  I am having issues managing the web gui interface from a routed vlan.     I have the switch configured with layer 3 vlans, and it is working fine. This is follow...
- Aug 05, 2015
Still cannot get the management vlan to change to a Layer 3 vlan, regardless of what RFC1918 address I use. However, I can now access the webgui from any of the ip addresses of the routed vlans, so there is no need to configure the management vlan to be accessible from any of the routed vlans. The issue was local to some of the pc's, these addresses had to be exempt from the proxy configuration for local LAN access.
Thanks for your time and patience resolving this issue.
DaneA
Aug 03, 2015NETGEAR Employee Retired
Hi bignewf93,
You may create another VLAN, let say for example: VLAN10 which is going to be within the 1010.0.0.x subnet range. Then assign port(s) to VLAN10 then change the port PVID to 10 then change the management VLAN to VLAN10. Lastly, make sure to set the IP Address to the 10.0.0.x subnet range.
Test it by connecting a PC to the port(s) assigned on VLAN10 and check that the PC is within the 10.0.0.x subnet range and you should be able to get a reply when you ping the IP Address you have assigned on the switch.
DaneA
Netgear Community Team
bignewf93
Aug 05, 2015Aspirant
