egnlsn
Sep 20, 2026Aspirant
GS305E and VLANs
I'm trying to get a GS305E switch configured for VLANs. The VLANs at the port on the router to which this switch is connected are 5 (main one) and 7. I need to configure this switch so that VLAN 7 ...
Sep 21, 2026Guru - Experienced User
schumaku wrote:Appears to me you don't have many different Plus switches.
The switches I am using now are
- GS728TPv2
- GS510TP
- GS108Ev3
and one other (unmanaged) Netgear switch.
I think that means only one "plus" switch model (the GS108Ev3).
schumaku
StephenB wrote:I think that means only one "plus" switch model (the GS108Ev3).
Correct.
And that's exactly one of these early Microcontroller based Plus switch generation with IP address and a Web UI, which does neither support non-tagged frames for the administration nor any non-default MTUs.
Clearly, the Web UI resp. the IP stack can't be reached over a fully all-tagged trunks as you claimed before. Sorry.
And for the same reason, it can't be discovered by NSDP based L2 discovery applications like the Netgear Switch Discovery Tool nor by the legacy utilities like the ProSAFE Plus Utility over a fully tagged trunk. Only untagged frames can reach and discover these.
- StephenBSep 21, 2026Guru - Experienced User
Well, it does work for me - I have no problem reaching the GS108Ev3 with the trunk fully tagged.
