ckruijntjens
Mar 26, 2026Guide
GS308EPP new firmware 2.0.0.11 bug?
Hi all,
I updated my firmware from 2.0.0.5 to 2.0.0.11 on 2 of 4 switches. On both switches i can not acces the web ui, And the switch is not responding on ping....
Anyone else having the...
- Mar 28, 2026
ckruijntjens wrote:
I have 4 switches connected to each other. All ports are using vlan and trunk ports.
Hello Chris,
First tell us a little bit more about your network. Understand you have a series of VLANs, all different from VLAN VID 1. And all are connected over direct Ethernet links, acting as a trunk. With each VLAN configured [T]agged.
ckruijntjens wrote:
If i put a port to pvid1 i can access the management webui. However i do not use this (Pvid1) i use different pvid config.
This makes the computer you are connecting (without a special VLAN config) assigning all frames -from- the connected device to the VLAN 1 on your network:
Is the same port also configured to participate in the VLAN 1?
Can you reach all switches over this VLAN 1, or do you have to repeat this on each switch?And since the intro of 2.0.0.11 on the GS308EPP/GS308EP (or 2.0.0.10 on GS305EPP/GS305EP) - introducing a Management VLAN - you can no longer ping or reach these nice switches anymore. What system or router had delivered the IP config before? On which VLAN did this happen?
Before the update, these switches were connected "flat" direct to a (V)LAN like a mobile phone on the Wi-Fi, connecting to a certain SSID. I assume there is no specially configured multi-SSID and VLAN capable wireless access point, where the SSID would be associated to a certain VLAN - the uplink from the AP does make up a trunk with tagged VLAN(s). When you use a wireless device (like a PC), you usually got an IP address. Does this IP and subnet come from your ISP router, or from a security appliance, a bigger, more complex multi VLAN and multi-subnet capable device?
This subnet - likely operated on one of your VLANs - is what you use as your Management Network!
All you have to do now is define that specific Management VLAN VID on the switch in the Advanced Dot1Q config. Now the switch(es) Management interface is yon the VLAN you desire, and no longer on the VLAN with the VID 1.
If everything is working after that, remove the ports where you had temporarely defined the PVID 1 from the VLAN 1.
You still have not answered my question if the field for the Management VLAN is empty (probably causing the problem!), or if there was a number configured.
Happy Saturday!
-Kurt
ckruijntjens
Mar 27, 2026Guide
Sorry,
My mistake vlan 0 is not used. It is vlan 1 that is default. And i leaved it that way. Indeed when i do the uograde the management interface is not reachable and i can not ping the switch. However everything keeps running. So data is arriving averywhere.
schumaku
Mar 27, 2026Guru - Experienced User
ckruijntjens wrote:... Indeed when i do the upgrade the management interface is not reachable and i can not ping the switch. However everything keeps running. So data is arriving everywhere.
Yes, exactly what I was understanding from your posts - this is why I've started brainstorming on what potentially went wrong.
You started from an appropriate and perfectly working VLAN advanced config for your use case with the VIDs 10, 11, 20, 40, 50, 60, 100. After the update from .5 to .11 - where the Management VLAN was introduced - switching continued working as configured - but any kind of management access was lost. After some experimenting on a GS308EPP, reverting to 2.0.0.5, factory defaulting, and deploy some random config with a handful VLANs in advanced mode, similar to your VID list. Updating to 2.0.0.11 showed the same effect: The switch management is no longer accessible.
Classic programmer bug, not properly initializing the variable where the Management LAN ID is supposed to be stored? Suspect somehow the in the Management VLAN, showing in the Web UI "empty" does have a kind of valid VID internally - wild guess it became 0 or 1. And there it goes, the management access.
MarcinS can you push this thread to the GS308EP/EPP and GS108EP/EPP RD and QA team please? This is very likely a bug, or at least an unintended mishap!
ckruijntjens wrote:Sorry,
No, nothing to sorry, you have opened my eyes: You have discovered a potential code issue!
- ckruijntjensMar 27, 2026Guide
Thank you,
So do i need to wait for a new firmware? If i put a port to pvid1 i can access the management webui. However i do not use this (Pvid1) i use different pvid config.
However thank you for replying. If i discovered a potential code issue im happy to inform :-)
Kind regards,
Chris Kruijntjens.
- schumakuMar 27, 2026Guru - Experienced User
Have configured the Management VLAN in the 2.0.0.11 Advanced 802.1Q VLAN config as per your effective network design requirements?
The PVID on a port does "just" define the VLAN incoming untagged frames will be associated to.
I'm under the impression that an "empty" Management VLAN setting (as it is after the update to 2.0.0.11, and 2.0.0.10 on the GS305EP/EPP) - unless the admin has explicitly defined the Management VLAN already - does implicit default to VLAN VID 1.
RobMendi wrote:
All was fine under 2.0.0.5 and now that I have updated them to 2.0.0.11, I cannot see the web UI to login.
Had left the Management VLAN config on the default (empty) setting following the update to 2.0.0.11, too?
- ckruijntjensMar 28, 2026Guide
Hi Schumaku,
Maybe you can help me with this one. I have my network setup like this. I have 4 switches connected to each other. All ports are using vlan and trunk ports.
When i configure the switches to pvid 1 on the trunk ports i still can not access the switches over my network. Only when i plug in a network cable directly to this port with my laptop.
What should i change so this is accasible for my network?
