Dave40
Jun 25, 2018Aspirant
GS510TLP Port flapping
So had a similar issue with a GS108T where the ports would flap down then up repeatedly causing internet to break. The GS510TLP has been updated to latest 6.6.2.9 firmware and RESET to DEFAULTS (whi...
- Jul 06, 2018
Since the bad cable was found I have not seen anymore port flapping. Strange that it affected several ports
Dave40
Jul 06, 2018Aspirant
FW v6.6.2.6 gave this (g3 is edimax WAP1750)
| <11> Jul 6 23:09:19 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(269) 2209 %% dot1sBpduReceive(): Discarding the BPDU, since it is an invalid BPDU type |
| <13> Jul 6 23:09:19 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(1246) 2208 %% dot1sBpduReceive(): Invalid Forward Delay |
| <11> Jul 6 23:09:18 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(269) 2207 %% dot1sBpduReceive(): Discarding the BPDU, since it is an invalid BPDU type |
| <13> Jul 6 23:09:18 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(1246) 2206 %% dot1sBpduReceive(): Invalid Forward Delay |
| <11> Jul 6 23:09:17 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(269) 2205 %% dot1sBpduReceive(): Discarding the BPDU, since it is an invalid BPDU type |
| <13> Jul 6 23:09:17 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(1246) 2204 %% dot1sBpduReceive(): Invalid Forward Delay |
| <11> Jul 6 23:09:16 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(269) 2203 %% dot1sBpduReceive(): Discarding the BPDU, since it is an invalid BPDU type |
| <13> Jul 6 23:09:16 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(1246) 2202 %% dot1sBpduReceive(): Invalid Forward Delay |
| <11> Jul 6 23:09:15 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(269) 2201 %% dot1sBpduReceive(): Discarding the BPDU, since it is an invalid BPDU type |
| <13> Jul 6 23:09:15 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(1246) 2200 %% dot1sBpduReceive(): Invalid Forward Delay |
| <11> Jul 6 23:09:14 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(269) 2199 %% dot1sBpduReceive(): Discarding the BPDU, since it is an invalid BPDU type |
| <13> Jul 6 23:09:14 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(1246) 2198 %% dot1sBpduReceive(): Invalid Forward Delay |
| <11> Jul 6 23:09:13 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(269) 2197 %% dot1sBpduReceive(): Discarding the BPDU, since it is an invalid BPDU type |
| <13> Jul 6 23:09:13 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(1246) 2196 %% dot1sBpduReceive(): Invalid Forward Delay |
| <11> Jul 6 23:09:12 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(269) 2195 %% dot1sBpduReceive(): Discarding the BPDU, since it is an invalid BPDU type |
| <13> Jul 6 23:09:12 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(1246) 2194 %% dot1sBpduReceive(): Invalid Forward Delay |
| <11> Jul 6 23:09:11 192.168.50.233-1 DOT1S[dtlTask]: dot1s_txrx.c(269) 2193 %% dot1sBpduReceive(): Discarding the BPDU, since it is an invalid BPDU type |
Dave40
| 0 | Jan 1 00:01:47 1970 | Spanning Tree Topology Change Received: MSTID: 0 g3 |
| 1 | Jan 1 00:01:45 1970 | Spanning Tree Topology Change Received: MSTID: 0 g3 |
| 2 | Jan 1 00:01:43 1970 | Spanning Tree Topology Change Received: MSTID: 0 g3 |
| 3 | Jan 1 00:01:41 1970 | Spanning Tree Topology Change Received: MSTID: 0 g3 |
| 4 | Jan 1 00:01:39 1970 | Spanning Tree Topology Change Received: MSTID: 0 g3 |
| 5 | Jan 1 00:01:37 1970 | Cold Start: Unit: 0 |
