PFACB's avatar
PFACB
GS724TPv2 Auto-VoIP Firmware Version
I have a number of GS724TPv2's and want to start using the Auto-VoIP features.  I can get them to firmware version 1.1.50.39 without issue, but read that if I want to go to the latest (6.2.1.13) it w...
  • schumaku's avatar
    Mar 13, 2026
    Mixing up different switch models? There is no v6.x.x x firmware for the GS724TPPv2. The major update step requiring erasing the config os the conversion from some v1.x via an intermediate version to v2.x. Follow the conversion stepsas documented carefully
    So yes, you have to take full notes of the complete  existing v1.x config, and re-do it from scratch on V2 x.
    As if writing, the current version is -> https://kb.netgear.com/000066697/GS724TPv2-GS724TPP-Firmware-Version-2-0-8-21
    V6.x only exists for the newer GS724TPv3 / GS724TPPv3 models.
ProSupport for Business
